I adjusted the frame before starting the process of putting the new top on; including straightening the horiz. metal pieces above the windows. After attaching the vinyl to the front header and installing the front header weatherstrip on Sunday, the driver side would not latch; the pin will not go into the hole. As I pull up on the latch, the front header comes slightly forward and the pin hits on the windshield frame; about 1/4 inch too far forward. The passenger side latches perfectly.
I loosened the frame attachment bolts and articulator arm bolt and move the frame back approx. 3/8 inch. That did not change anything at the front header. I don't really understand the adjustment of the articulator arm. If I raise it up at the attachment bolt (near the frame attachment bolts) and tighten it, does that make it pull up over the window? What happens when the arm is bolted down at the bottom of the oval hole at the attachment point?
I don't know what else to adjust to make the latch pin move back far enough to go in the hole. Any suggestions?
