Re: 1966 engine temp & HEI
Ported vacuum advance was an early emission control strategy. The engine will operate better (lower fuel consumption, less tendency to run hot, and better normal street and highway speed driveability) with full time vacuum advance, but it's usually NOT just a matter of replumbing the vacuum can signal line. It often requires substitution of a different spec vacuum can and recurving the centrifugal.
I would have to know the specfic year, engine option, and OE ignition map specs to make a recommendation.
The only C2s with ported vacuum advance are '66-'67 CA models. Also ALL L-72s have ported vacuum advance, and I think all L-71s are also ported. My theory on this is that L-72/71 were set up to comply with CA emissions and this version was sold in all 50 states because, as a low volume option, Chevrolet chose to sell these engines in just one configuration as a cost/inventory savings measure.
A number of L-72 owners have switched to full time vacuum advance along with installing a different vacuum can and report better overall driveability, and in particular, less tendency to run hot or overheat.
