'66 BB EXHAUST MANIFOLDS(NO GASKETS) - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    I had the exhaust manifold surfaces machined at a reputable engine building shop. I'm thinking of installing them without gaskets, as original. Is there any high temp gasget maker that I might lightly coat them with before installation? The left one, with the stud that mounts the alternator and power steering pump brackets is quite a bit of work to remove in the event it leaks at all. I realize there was no gasget or sealer originally, but I wouldn't mind using a little sealer for insturance against any minor leaks. I've been told the ultra-high temp red can be used for this.
    Re: '66 BB EXHAUST MANIFOLDS(NO GASKETS)
    Rob-----
    I don't think that there is any sealer commonly available that will withstand this heat. I wouldn't use any, anyway. If you've had the manifold surfaced, you'll be fine. Most of the time, even if the manifold is not surfaced, it won't leak.
