My early 69's wiper motor has a clip on top that from all indications should have a ground wire connected to it. In fact, the only way I can get the motor to run is to ground it but I can't find any evidence of a ground wire on the car. Can someone please tell me from where the ground should be coming (i.e. a wiring harness) or if it is simply grounded to something?
Another problem I have is that to initially get the wiper motor running I must ground the motor but then it will not cut off, even when the wiper switch is in the off position, until I remove the ground. Once removed, the motor remains off until the switch is turned on again. Can anyone shed any light on this rather bizare behavior?
Thanks in advance,
Jack
Thanks in advance,
Jack
