popping thru exhaust - NCRS Discussion Boards
  • Michael F.
    • 745
    right side on my big block with side pipes has a popping sound at idle, andy ideas what this may be. rebuilt engine and new valve job, springs not replaced as they were good.
    Michael
    70 Mulsanne Blue LT-1
    03 Electron Blue Z06
  • Craig S.
    • June 30, 1997
    • 2471
    Re: popping thru exhaust
    Michael - it might be related to the heat riser valve.....leaking air into the exhaust....Craig
    • Michael F.
      • 745
      I do not have a heat riser instead I have the spacer which in effect is just like the drivers side.
      Michael
      • Terry D.
        • May 31, 1987
        • 2690
        Have you taken a compression test? That would be my first step, check all 8 cylnders. Is timing correct? Too much timing causes too much heat and burns valves rather rapidly. Been there done that. What year big block?
        • Joe R.
          • July 31, 1976
          • 4547
          Michael,
          Where did you get your side exhaust system? The after market ones have the popping sound built in. Allens has the correct machine (bought walker's original) now to fashion correct sounding side pipes. Also, old original pipes have been known to get a little rusted out and become louder.
          JR
          • Rick A.
            • July 31, 2002
            • 2147
            check plug wires and make sure they aren't crossed - been there done that!
            Rick Aleshire
            2016 Ebony C7R Z06 "ROSA"
            • Joe C.
              • August 31, 1999
              • 4598
              If it is not a steady pop, then it might be a bit lean. Try turning your idle mixture screws out 1/4 to 1/2 turn (richer). This may just solve it.
              Joe
              • Michael F.
                • 745
                it is a 67 427/435, rebuilt with stock components, factory chevy side pipes that were bought new from chevy in mid 80s. I will try carb adjust, but it just seems to be on one side and compression checks ok. It does have 2 new valve springs but not sure what head they are on. The pop (backfire) is on left side only....
                Michael
                • Terry F.
                  • September 30, 1992
                  • 2061
                  If you have an over tightened exhaust rocker arm, you will get the same results. Not sure if someone posted that yet. Compression check may show it. If it is happening only out of one side of the exhaust, I would suspect that. Terry
                  • Michael F.
                    • 745
                    Thanks Terry I will check that too.
                    Michael
                    • Terry F.
                      • 2061
                      The other thing that can cause this problem is a small exhaust leak. When things get warmed up and under the right circumstances, cool air can get sucked into the pipe through a crack/small pin hole and cause a small popping sound from exhaust gasses reigniting inside the exhaust chamber. Sorry if someone already suggested this. Regards, Terry
