Front Fender Stainless Trim - NCRS Discussion Boards
  • Ray C.
    • June 30, 2001
    • 1132
    Hi!
    Could someone please email or post a picture of the stainless trim on the front fenders of a 1961? I am especially interested in the reveal on the wheel opening side of the trim.
    rcarney5@rochester.rr.com
    Thanks for any help!
    Ray #36314
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
  • Brad K.
    • August 31, 1990
    • 414
    • Ted L.
      • May 31, 1999
      • 101
      Re: C1 - Front Fender Stainless Trim
      Ray/Brad,
      Had the same problem with SS from CC. It can be bent but it ain't easy. I sandwiched mine between two pieces of 3/4 inch plywood along with the appropriate thickness of spacers and very slowly and carefully applied the necessary pressure to the rounded leading edge to bend it. The plywood keeps it from crimping. I was told later that judges don't expect it to fit perfectly.
      Ted
      • Ray C.
        • June 30, 2001
        • 1132
        Hi!
        Thanks for the responses! I would still like some pictures of an original fender with the stainless trim. I had to correct a previous restoration on the front right fender and would like to confirm location before the final coat of lacquer.
        Again Thanks!
        Ray #36314
        Ray Carney
