Air Filter Element - NCRS Discussion Boards
Air Filter Element
  • Joe C.
    • August 31, 1999
    • 4598
    Air Filter Element
    I'd like to replace the original foam type air filter element with a modern paper element. The car is a 1965 327/365. A/C number preferred.
    Does anybody know if the K&N replacement yields any advantages. The K&N looks like it is of the same (tedious) design as the original, which means frequent baths in gasoline and motor oil.
    Joe
    Re: Air Filter Element
    Joe-----
    What you need is an AC 353C also known as GM #6484339. Unfortunately, this filter has recently been discontinued from the GM parts system. However, you may still be able to get it through the AC-Delco parts system from Delco dealers.
    • Eugene B.
      • May 31, 1988
      • 710
      Joe 32899,
      I purchased this filter from Paragon last fall. It is not listed in their catalog, but if you describe it as A353C Paper Element, they will provide it for $10.
      Gene
      • Joe C.
        • August 31, 1999
        • 4598
        Thanks Joe And Gene *NM*
