Rear spring bracket finish? - NCRS Discussion Boards
  • George Daina
    finally found someone who can drive the vette. 67 427/435, M-21, 3.55.
    12.9 at 111 MPH. High Performance Cars, May 1967. The following is very interesting.
    The mag tried to get a number of BB vettes for a road test but got a lot of evasive answers, so they called Joel Rosen at Motion Performance, Baldwin, N.Y., he secured a custemer's car that had 12,000 on the clock.
    "Joel secured for us a well broken in 67 Corvette ragtop with 4 speed, 435 HP engine. Joel also volunteered to assist us with the road test, since he has owned and competed (draged) with a great variety of Sting rays since the first was introduced in 63. Since the car was privately owned and not a factory car, we limited our testing to a couple of days and did away with some of the BANZAI BLAST-OFFS."
    They went to say that in 1st and 2nd, the car was sluggish, and concluded that it was stictly a top end machine. All owners of M-21's & 3.55 gears will agree with that statement.
    Another area of concern was the shifter/linkeage: "We also felt that the car's performance was hindered by the four speed likeage supplied by the factory. In the past, most Corvettes equipped with four speeds had the nasty habit of transmitting some vibration to the pilot via the shift linkage. All traces of shift line vibration are gone, but the likage itself is too stiff for quick power shifting. It's too easy to get hung up in neutral and spill the beans. The new Muncie linkage setup runs off a chassis-mounted bracket which also supports the pulleys for the cable-controlled rear parking brake."
  • Tom B.
    • February 1, 1994
    • 779
    Re: Used ta love them Cubbies
    Mike,
    I know what you mean. You could practically always count on them to blow it. Every fan would watch till the last out. Left for other reasons though, 'Vettes was one of them. Still have a soft spot. Tom #24014
    • Dave Christensen
      What finish should the rear spring mounting bracket have?
      Front bracket that mounts to the frame?
      Center plates that mount to the differential with U-Bolts?
      Rear shackels?
      What finish should the small L shaped brackets at the end of the e-brake cables have?
      thanks Dave Christensen
        • August 31, 1999
        • 155
        What year is your car? *NM*
        • Dave Christensen
          Re: What year is your car? Ans: 1956 *NM*
          • Richard and Ann McNally
            additional information
            The plate that I am referring to is the plate on the left under the glove box, and this one under the trim section clearly has 430HP stamped on it. Most of the plates I have seen do not have any HP rating on them, so I do not know if this is a real plate or a fake.
            • Bill Clupper
              Re: additional information
              The '67 VIN does not carry an engine designator, nor was the HP stamped on the trim tag in any available factory documentation.
              • Wayne W.
                • April 30, 1982
                • 3605
                Re: car help please
                The HP is the exceptions code. Means this car was equipped with sholder harnesses and hardtop, but not with electric windows, headrest, or automatic.
                • Michael W.
                  • April 1, 1997
                  • 4290
                  L-82 RPO was not available until 1973, but
                  I suppose you were hoping that the car was an L-88.
                  Mike
                  • Ed Jennings
                    Re: L-82 RPO was not available until 1973, but
                    Read somewhere not too long ago that at least 35 of the original 20 L88's were known to exist, all with complete documentation. Hummmm.....
                    • Michael W.
                      • April 1, 1997
                      • 4290
                      and the number goes up every year.... *NM*
