Aluminum Valve Covers/Again - NCRS Discussion Boards
  • Bill C.
    • December 1, 1991
    • 177
    The covers for this car (presently off) are badly oxidated (grey) and would like suggestions to renew the finish without POLISHING them. All help appreciated............Thanks, Bill #20328
    • 11608
    Jerry MacNeish
    See Link Below.
    • Dennis Russo
      Re: Jerry MacNeish
      Jerry MacNeish has cleaned up my aluminum intake, valve covers, and rebuilt the 4-speed on my '65--his work is EXCELLENT, his prices are very fair for the work done, and I would (and have) recommended him to anyone interested in this type of work.
        • 11608
        Re: Jerry MacNeish
        Absolutely.
        The only other options I can think of are light bead blasting, aluminum wheel cleaner, or other somewhat abrasive means. You won't get the correct appearance, but you will get rid of some of the corrosion.
        Jerry's process sprays a thin layer of aluminum on the parts, and for whatever reason it seems much easier to work with than the original surface. I've found mine easier to clean after they have been reskinned.
        Patrick
        • Gary B.
          • February 1, 1997
          • 6979
          Don Dorfman is another excellent choice
          Guys,
          Don Dorfman should also be able to restore valve covers. Don has been reskinning aluminum intakes for years and doing a superb job at it. I think his company used to be called ALS or something similar, for the old timers. With intakes, the last time I checked Don was slightly less expensive than Jerry MacNeish and as I said his work is top notch.
          Don can be reached via e-mail at: nw_guy4_fun@yahoo.com
          Gary
          • kenneth bingener NCRS#38563
            Has anyone tried P21S? *NM*
