Re: The finish is done on a Brake lathe.
The actual process was done using a silicone carbide grinding wheel instead of a tool bit, or at least that's the way it was supposed to be done. The two leave a totally different finish if viewed close up. The machining process with a tool bit actually chips away at the material and leaves a rather jagged surface but the carbide wheel isn't a chipping process. I suppose if the drum cutting process were done as you described, slow feed and minimum cut, it could come colser to the correct ground surface.
I'm still looking for one of the small instruction sheets that came packaged with new met brake linings because that gave us the speed/feed for this operation and if I find it. I'll post it.
I noticed the link I posted earlier doesn't work when clicked on. May have to manually enter it into the address bar.
