1966 427/425 Air Cleaner Element - NCRS Discussion Boards
  • Peter M.
    • February 1, 1984
    • 361
    Re 1966 427/425 Air Cleaner Element - Are you aware of any vendors who offer factory correct air cleaner element with correct filter paper, mesh and rubber attributes to original ?
  • John L.
    • 409
    Re: 1966 427/425 Air Cleaner Element
    Peter - I got mine from paragon. It was around $30. I lost one point because the judge didnt like the way the silk screening on top looked.
    • Peter L.
      • May 31, 1983
      • 1930
      John - From your reference to the silk screening on the top, it sounds like the judging was conducted prior to the release of the 4th Edition of the 1966 TIM&JG. The AIR CLEANER Filter Element (p. 74) has been revised and updated to reflect new information. Pete
      • Peter L.
        • May 31, 1983
        • 1930
        Peter - If you are refering to the AIR CLEANER FILTER ELEMENT as described in the most recent edition (4th Ed.) of the 1966 TIM&JG, no one makes one exactly like AC did back in the '60s and was used on the 1966 production year Corvettes yet. The AIR CLEANER FILTER ELEMENT description paragraph in 4th Edition of the 1966 TIM&JG has been revised from the version in earlier editions based on new information and examples of original AC A212CW air filter elements installed on 1966 Corvettes and maufactured in the 1965 - 1968 time frame. Time will tell. Pete
        • Peter M.
          • February 1, 1984
          • 361
          Thanks Peter *NM*
