1958 C1 Master Cylinder Finish - NCRS Discussion Boards
  • Ken Susnjara
    I purchased a replacement master cylinder for my 58 and would like to know what type of finish, if any, should be used on the outside. Thanks.
  • John P.
    1956-57 Team Leader
    • April 30, 1992
    • 63
    Re: 1958 C1 Master Cylinder Finish
    Either natural or black.
    • Ken Susnjara
      Thanks.
      • terry leeker
        Ken, I would expect the front and inboard side of the master cylinder to show the engine compartment black-out paint and the outbord side to have the cast iron natural appearance due to it's installation on the firewall before the black-out process.
        • John M.
          • January 1, 1999
          • 1553
          Terry,
          Actually, if I remember some photos correctly, The M/C was mounted to the brake line and went down the line with the chassis and not the body. I think that the M/C did not get attached until the body drop.
          Regards, John McGraw
          • terry leeker
            John, in doing my '58 restoration (first on that car) the firewall under the M/C had red body color overspray but lacked blackout where it mounted and also had a blackout holiday adjacent to MC on the outboard side.
            • John M.
              • January 1, 1999
              • 1553
              Terry,
              I am just going by the pics on page 126 abd 144 in Nolans book of the chassis right before body drop, and both of them show the M/C hanging from the brake line. They may have changed in later years, but there no more pics in Noland book of a front view of a body drop after the 57 model year.
              • terry leeker
                Interesting. That's what I like about this pastime, another little mystery to unravel. An aquaintance of mine is doing a frame-off on a very low mileage, unmolested, '58. I'll see if his M/C has blackout paint underneath and report back.
                  The master cylinder was always part of the chassis prior to body drop, so the brake system could be bled and pressure-tested on the Chassis Line; it just hung on the main brake line until after body drop, when it was pulled rearward and attached to the firewall pedal support studs.
