A few weeks ago there was athread agout cleaning the undercariage. I said at the time I thought the simple green cleaner I had used might promote rust.I did a little test by putting some of it into a coffee can along with a few metal parts. The rust on the inside of the can and the small parts is unbelievable,the top was on the can so no air got to it.The front half of my car was cleaned with Gunk and the back half with simple green and both sprayed with a small pressure washer. no rust visible to speak of any where when I started. The back half srayed with simple green now shows quite a bit of rust.I geuss my point is stick with the Gunk. I know I won't use simple green again.
Tom Stanton
#41491
Tom Stanton
#41491
