... the one that was never installed on a factory production line engine: tach drive, ball bearing upper, no vac advance (fixed plate), w/early big block-type 90 deg. filled lower oil channel, and reverse rotation cam driven gear.
Just acquired an NOS unit and want to pull the shaft to examine lube situation -- the small quantity I see on the exposed end of the tach driven gear looks pretty dried-out.
So, are the ball bearings held in a race, or are they going to spill out and be impossible to re-insert ? Do you just pull the shaft out like the regular distrib's ? Is the shaft unique ? Where would you find GM parts catalog that lists the part #'s for comparison with factory ?
