Re: mid year paint strip
Jack,
I think you have the best method of all. Removing the factory primer with sand paper will do it faster but will also remove all traces of the original "character" of the fiberglass in the areas that were never sanded at the factory. I'm with you on the lacquer thinner/rag thing.
I think the thing that is most disturbing to me is seeing any restored Corvette that has body/paint that looks like a Mercedes and if the last of the material is sanded off, that's what you will wind up with. The fiberglas panels weren't smooth to begin with and they definitely shouldn't be after restoration. Very little sanding was done at the original source of the panels and ONLY THE PART OF THE BODY ABOVE THE BODY LINE WAS SANDED AT ST. LOUIS. If you ever get the chance to really study an original paint car, you would clearly see that most of the area below the body line is rough and in areas like inside the louver panels, you can see the raw outline of the fiberglass in the totally unsanded panel. The glass wasn't sanded in these areas and the primer wasn't either. If the last of the primer is removed with 220 paper, that grain or texture goes with it and you wind up with the Mercedes look. Everyone seems to believe that you have to sand the glass to get proper adhesion but if you think about it for a moment, you'll realize that the factory sure didn't sand all the primer and their paint stuck pretty well.
Someone could/should write an entire book on the correct way to strip and refinish a Corvette back to the way it was originally, and another book on how NOT to do it. I would hope the entire first chapter would deal with NOT sanding the bare glass, especially in areas like the hood trough or the louvers on a 63-67 car. Once that texture is gone, it's gone forever.
The next original paint car you see, look at the rough grinder scars on the edges of both doors, the grinder scars under the front lower panel below the grille and many other areas around the car.
Over the last 25 years, the chassis restoration process has come forward and we've all learned a lot but as far as body and paint, I see little change from the days of NCCC where the paint and body are perfect. It just wasn't at all that way. If ya want a Mercedes, buy a mercedes but please don't destroy any more Corvettes. The next owner may want to restore it properly.
Michael
Jack,
Michael
