C2 Hood Blackout Question - NCRS Discussion Boards
  • Mike M.
    • September 30, 1999
    • 710
    The Lip under the hood is body color all the way around if I'm reading things correct. The hood was in place when the blackout was applied. Front of hood may not have total coverage. Can you see any overspray of body color on the lower part of the hood where blackout missed or was thin. Also if using shims under the hinge were these in place and should have blackout paint on there edges.
    Thanks Mike
  • Gene M.
    • April 1, 1985
    • 4232
    Re: C2 Hood Blackout Question
    Mike,
    The front lip edge of the hood should be more bare fiberglass than any overspray. This was painted with the hood in place and adjusted to the body. Thus the hinges and shims may see paint overspray.
    • Mike M.
      • 710
      Gene, Is there any body color overspray on the underside of the hood.
      Thanks Mike
