anyone make the colored fuses?
colored fuses
Re: colored fuses
Long Island has them..........differences from theirs and the originals is the painted stripe is on the outside of the fuse glass. But they will be the closest you will find without hitting the junk yards. If you take a pencil you can tell by putting a small line over the painted mark. If you try this on origianl fuses you will not leave a mark.1967 L79 Sunfire Yellow Black Leather Convertible- Duntov
1969 L71 LeMans Blue, Bright Blue Convertible
1970 L46 Monza Red, Light Saddle Convertible - Duntov
1976 L82 Classic White, Firethorn
2013 LS7 Black, Ebony, Convertible
Moved on -
2006 LS2 Black, Ebony, Convertible- Top
Re: colored fuses
Lyndon - As mentioned LICS has reproduction colored fuses and I generally regard their manufactured parts as some of the best. But, the colored fuses I've seen and I'm assuming they came from LICS are just that "colored" fuses in name alone; kind of like "round" steak, i.e steak in name alone. They just don't look like the original color codes glass fuses and a judge should surely know the difference and as mentioned the color band is on the outside of the glass; where the original Buss fuses had the color band on the inside of the glass. Pete- Top
