Three things on the carb of a 67 327/300 hp engine:
First, which type of bowl and metering block gaskets generally work the best? There is the more original one-time use type, and then there is the blue "reusable" types also. I have the blue ones on there now, but I can't seem to get the secondary bowl to stop seeping (doesn't drip, but is generally wet to the touch). What type/brand seems to be the most leak tight?
Also, when adjusting my two mixture screws, I have noticed that the drivers side ends up about only 1/2 turn out while the right side is about 1 1/4 out (when adjusted per service manual). Also, I can turn the drivers side all the way in to seat and the engine keeps running while seating the right side kills the engine right away? What is this a symptoms of?
Does the heat riser on the right hand side have any effect on idle mixture adjustments if I were to wire it full open?
