66 Water Pump - NCRS Discussion Boards
66 Water Pump
  • Jerry Clark
    66 Water Pump
    66 SB AC with A.I.R. 350 HP
    I need the dimension from the pump hub to the end of the pump shaft.
    I appreciate any help as always
    jerry
    Re: 66 Water Pump
    Jer, from the mounting leg surface to the pulley mount surface on the face of the hub, it should be 5-9/16", or 5-7/16" if the pulley has an internal reinforcement (thanks, Joe )
