I seem to remember some discussion in past posts regarding a "dimple" of some sort on the front cowl ledge, about 16 cowl/plenum grille slots in from the driver's side end. This was represented as a sure way to tell if a car was original and had not had a new front clip during its lifetime. Is there anything to this? I did an archive search but couldn't find anything. Thanks!
C2 Cowl "dimple"
Re: C2 Cowl "dimple"
I think it is on the 13th slot. I can check for you tonight. It is used more of an indicator as to whether or not the car has been repainted, not necessarily whether it has a new front clip. The dimple is usually sanded off during the paint prep work. Again - not an indicator of body damage or replaced clip.- Top
Don,
It's real. It's about 1/8" in daimeter and in the fiberglass from the original mold. It's only on the left side of the car. Problem is, any "tuned-in" body man/painter today will add a drop of resin to new glass parts before painting to duplicate the bump and make it look original.
Hanson- Top
Mike,
Your absolutely right. I just looked at the 66 and that bump really does look like a small drop of paint under the primer. That wouldn't be difficult to duplicate. Bet the original glass weeve and texture would be tho, if it were sanded off. I think I spent about 8 hours stripping just that channel on the car so the texture in the glass stayed the way it should be. I also have to wonder why we go to these extremes to save something like that. Must be the love for these cars, right? My girlfriend thought I needed psychiatric help when I showed her the grain in the raw glass channel.
Hanson- Top
Re: Not a dimple, It rises above the surface.....
The one on my car isn't cone shaped. It looks like a drop of resin and it's rounded on top. It's about 1/3 as high as it is wide. Every one I've seen is just about exactly this way.- Top
Re: Not a dimple, It a Pauple
Mike,
Maybe we should see if we can get that added to the judging sheet. "pauple on left hood ledge". Sounds like a little animal.- Top
Bill,
I'll see if I can get a decent pic of the dimple, or whatever it's called. May be difficult because it now has a few coats of paint but I'll give it a try.- Top
