Aligning Shark Headlight Buckets - NCRS Discussion Boards
  • Michael H.
    • July 31, 1998
    • 180
    What's the correct procedure for aligning the headlight buckets on a 1974 Corvette?
    Re: Aligning Shark Headlight Buckets
    Mark-----
    The headlamps are adjusted using 2 screws located near the rim of each capsule (sealed beam/retaining ring/"bucket"). However, to perform this adjustemnt properly you need a a HEADLAMP ADJUSTER. These can be purchased from Kent-Moore (J-25300-D) or from others for about $1,000. Most folks with any sense about them (which, unfortunately, doesn't include me) don't consider this a wise investment and take their cars to someone that has the equipment to have it done for about $25.
    There are some other ways to do the job using improvised procedures (i.e. shining the lights on a flat surface with the car a certain distance away) and using a procedure to adjust the beams with the adjusting screws. However, headlamps are a very important SAFETY item. The best bet is to have it done properly by someone with the right equipment. It only takes a few minutes and you shouldn't have to leave the car as it's usually done on a while-you-wait basis.
    • Harmon C.
      • August 31, 1994
      • 3228
      Mike I have a plastic tool I bought years ago that rests on the three glass tabs that are groud true on all round headlights. It is easy to use but you may need to ask your car friends if they have this tool you could borrow. If you see one at a swap meet it is yellow with a level on it. Lyle
      Lyle
      • Michael H.
        • July 31, 1998
        • 180
        Perhaps I wasn't clear in my post. I need to align the BUCKETS, not aim the headlights.
        • Chuck R.
          • April 30, 1999
          • 1434
          I can send you a cut sheet from my A.I.M. that briefly descibes the process if you would like.
          Let me know.
          Chuck 32205
          • Chuck S.
            • April 1, 1992
            • 4668
            Also in the Chassis Service Manual if you have one...Section 12, Electrical-Body and Chassis, "Maintenance and Adjustments".
              Mike------
              Other than the final headlamp aim adjustment that I discussed, there is no alignment procedure necessary for the "buckets". They get "aligned" when the headlamps are aimed.
              • Chuck S.
                • April 1, 1992
                • 4668
                Joe, I think he's talking about adjusting the doors to the body, and you're talking about the black metal cups that hold the headlights.
