C2-Brake Pads - NCRS Discussion Boards
C2-Brake Pads
  • john lokay
    C2-Brake Pads
    What type/make of brake pads should I install on my 66' that best prevents brake squeal? Whatever they maybe, I plan to trim the edges to prevent potential squeal as outlined in the Chevy Technical Service Bulletin, dated 8/20/65, which was reprinted in the sring 2004 issue of the Restorer.
  • Timothy B.
    • January 1, 2004
    • 438
    Re: C2-Brake Pads
    I used the inexpensive organic pads available at your local auto store and they don't squeal at all, with no special action required.
    • Wayne K.
      • December 1, 1999
      • 1030
      Re: C2-Brake Pads
      John,
      Organic pads are also low dusting. RayBestos also has a fine line of brake parts that perform well and are low dusting.
      Wayne
      • Rich G.
        • August 31, 2002
        • 1396
        Re: C2-Brake Pads
        John
        I got a response off line as a result of your original post. I don't know if you got one too, but my issue was a squeal at light braking only. I was told this is caused by the interface between the back of the pad and the piston, not the pad on the disc. I was told that you can buy "anti-squeal adapters" at most auto parts stores which go between the pads and the piston. It was also suggested that a dab of hi-temp RTV on the back of the pad works.
        I have not tried either yet. I thought I'd pass this along FWIW.
        Rich Giannotti
