C2 VENT GLASS REPAIR - NCRS Discussion Boards
  • Jerry W.
    • August 31, 2001
    • 29
    I had to repair the vent window frame on a 67 Roadster and now need to put the glass back in the frame.. The original rubber seal is rotted.Any one have any experience on replacing the rubber seal between the glass and the frame?
  • Joe R.
    • July 31, 1976
    • 4547
    Re: C2 VENT GLASS REPAIR
    Jerry,
    No problem. Just go by any glass place that sells window, door and car glass. Show them the piece and they will give you the correct stuff. If you want a little ease of installation use some lighter fluid and then let it set overnight before installing it back in the car.
    JR
