Sagging Rear End - NCRS Discussion Boards
Sagging Rear End
  • Cameron Mountenay
    Sagging Rear End
    Now, before the personal comments come out; my question is about the cars rear end. I have a 1973 convertible. Before restoration it sat nice and square. now after new body mounts and a replacement rear quarter pannel were installed the car tilts down on the left side. It seems too low. The rear spring is not too old. I am looking for some suggestions. thanks
  • Wayne P.
    • August 31, 1975
    • 1025
    Re: Sagging Rear End
    Measure frame to floor and body to floor on both sides to see which is the problem. If frame, you might need new rubber isolaters on the spring or an adjustment on the outboard mount bolts. If the body, your Qtr panel was put on wrong or the body mounts are in correctly installed.
