Torque Specs. - NCRS Discussion Boards
Torque Specs.
  • Ray C.
    • June 30, 2001
    • 1132
    Torque Specs.
    Could someone please provide the torque specs? For the lower A-arm pivot shaft bolts. Car is a 1961.
    Thanks for any help!
    Ray
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
  • Chuck R.
    • April 30, 1999
    • 1434
    Re: Well Ray,
    Seeing from all the responses you got back, I figure "what the hey", someone should at the least respond back to ya!
    According to my 68 A.I.M. my lower control arm bushing retainer bolt has a 45 to 55 Ft. Lb. spec.
    Chuck 32205
    • Chuck R.
      • April 30, 1999
      • 1434
      Re: Well Ray,
      Chuck 32205
      • Al C.
        • July 31, 1999
        • 274
        Re: Torque Specs. C1 lower A-arm
        Ray -
        The ST-12 indicates lower A-arm shaft (inner toward body) bushings torqued at 85-100 ft-lbs.
        The lower outer bushing at 150-170 ft-lb, with the pivot bolt at 100-200 ft-lb, and the nut at 90-120 ft-lb..
        ... Al '58 #378
        • Al C.
          • July 31, 1999
          • 274
          Ray -
          ... Al '58 #378
          • Ray C.
            • June 30, 2001
            • 1132
            Hi!
            Thanks for the responses. I determined the bolt sizes and torque according to bolt size. (50 to 55 FT LB)
            Thanks again!
            Ray #36314
            Ray Carney
            • Ray C.
              • June 30, 2001
              • 1132
              Hi!
              Thanks again!
              Ray #36314
              Ray Carney
