Re: C2 Wheel Alignment
By the mid seventies there were three sets of specs - reset, warranty, and state inspection. The latter contained the very widest range.
Like I said, alignment is a tuning parameter and like engine timing there is no one magic number, but a range that is usually acceptable in most driving conditions.
I disagree with Terry on intentionally setting in cross caster to offset road crown.
If the chassis is straight and everything is equal side to side the car should track dead straight on a level road. On modern roads with minimum crown it should drift slightly to the right, but the amount of correction to keep it tracking staight is virtually unnoticeable This is what you want, so if you fall asleep the cars drifts off to the right and not to the left, potentially into the path on oncoming traffic on a two lane road.
I previously mentioned the difference in toe requirements for radial versus bias ply tires.
