C3 brake caliper paint - NCRS Discussion Boards
  • Steve King
    I replaced my brake calipers and I would like to paint the new ones as close as possible to the original color. The car is a 1980. What paint should I use? Manufacture and color would be helpful.
    Steve
  • lyndon Sharpton
    Re: C3 brake caliper paint
    you might check with the Eastwood CO. when I did mine if I remember I used a high heat black paint from a spray can. it has heald up well. I do not know what color a 1980 would use I would think they would be black also?
    • lyndon Sharpton
      • Craig S.
        • June 30, 1997
        • 2471
        VHT makes a brake caliper black that is the correct color and durability for the calipers.....Craig
        • Craig S.
          • June 30, 1997
          • 2471
          • Tom S.
            • March 1, 2004
            • 1087
            I would like to paint the ones on my 69. What color should they be? Or are they a natural cast color?Thanks in advance.
            Tom Stanton
            • Tom S.
              • March 1, 2004
              • 1087
              Tom Stanton
                Tom -
                They were painted black, prior to machining.
                  Tom -
