C3 T-Top Leaks - NCRS Discussion Boards
C3 T-Top Leaks
  • Michael H.
    • July 31, 1998
    • 180
    C3 T-Top Leaks
    Just completed a body off restification of a 1974 Corvette. The car is leaking around the front and rear of the T-Tops so much it makes you think you're in one of those WWII submarine movies! They are "tight" and have new weatherstrip - what am I missing????
  • lyndon Sharpton
    Re: C3 T-Top Leaks
    Are you sure they are on tight? is the weatherstrip on with out kinks an is not binding?
    • lyndon Sharpton
      Re: C3 T-Top Leaks
        Re: C3 T-Top Leaks
        Are the voids between the inside of the stainless trim moldings and the steel birdcage structure filled with sealant?
          Re: C3 T-Top Leaks
          • Tony Roussos
            Re: C3 T-Top Leaks
            Greetings.
            Have you removed all trim and verified it is the tops?
            Sometimes door glass misalignment looks like top leakage.
            I also agree with John. Make doubly sure all voids and cracks are sealed well.
            Tony
            • Tony Roussos
              Re: C3 T-Top Leaks
              Greetings.
              Tony
