K,
Yes, you should be able to use a standard 350.
One question I have is why you believe that it will be less expensive to build a second motor than to de-tune yours. The standard 350 components which were installed in these motors generally was not of high performance potential, unless you had an L-82. Now I will confess that I do not know whether the 81 had forged pistons (vs cast) as there was only one motor, but knowing GM, I doubt it. If so, using standard rebuild kits should be all you need. In other words, it will be LESS expensive to rebuild your present motor than to rebuild one twice.
In addition, I hate to say it, but your Corvette motor was, in base form, really not much different than a passenger car engine. The induction (carb) was different, but likely again, little else.
Also, you may find that the short block in yours still has original components, and that only the cam was changed. If so, it may cost you even less to rebuild it. Do you have receipts from the previous owner as to what was done?
I would HIGHLY suggest finding someone in your area that can help you IN PERSON examine your engine casting numbers, head castings, etc to see their origin. Then, consider having them take the engine apart and giving you an opinion BEFORE further work is started. You may even be able to just pull the heads off the engine and examine them for porting and polishing, as well as then view the pistons, without having to remove the motor.
Good luck.
Patrick
Good luck.
Patrick
