I have a 67 327/350 (L-79). I pulled the distributor and found that the drive gear dimple is pointing about exactly the opposite as the rotor tip. Therefore I need to rotate the drive gear so that the dimple and the rotor tip line up.
Never done this before. How do I remove the roll pin that is holding the gear on and then put it back in? Any special tools needed?
Thanks!
Nick
Thanks!
Nick
