INTAKE GASKET CORK? 1957 - NCRS Discussion Boards
  • Dan P.
    • December 1, 1990
    • 683
    WERE THE BLOCK GASKETS FOR THE INTAKEE CORK ON THE THE ORIGINAL 57 ENGINES OR DID THEY HAVE THE GM MARKINGS
  • Steve Junkersfeld
    Re: INTAKE GASKET CORK? 1957
    Dan, I'm not sure about the markings, but I'm fairly certain they weren't cork. They were probably the same black fibrous material as were used on my 56. Steve
    • Steve Junkersfeld
      • Mike M.
        • May 31, 1974
        • 8365
        the seals , on each end of the intake, which seal between intake and block, were rubber, not cork, and i'm fairly certain the had a square tab with GM embossed thereon. mike
        • Mike M.
          • May 31, 1974
          • 8365
          • Steve Junkersfeld
            Dan, Mike is absolutely correct - had I read your question closer, I would have realized you said block gasket. The seals at the head on the intake are as I described. Sorry, Steve
            • Steve Junkersfeld
