Duramix Fiberglass Panel Adhesive--Any Good? - NCRS Discussion Boards
  • Craig S.
    • June 30, 1997
    • 2471
    #31
    Re: Duramix Fiberglass Panel Adhesive--Any Good?
    Scott - Lord corps FUSOR line has some very nice handling two part epoxy bonding adhesives that work well with SMC, Genite, polyester, or dissimalar material bonding like metal to glass. Also, there is one that works well as a filler for bonding seams after the bond is complete, and if I recall, you have a few choices on the kick time involved, for larger panels such as hood surrounds, more time is required.....Craig
    • Terry F.
      • September 30, 1992
      • 2061
      #32
      What is FRP? Thanks, Terry
      • Terry F.
        • 2061
        #33
        • Chuck S.
          • April 1, 1992
          • 4668
          #34
          Fiberglass Reinforced Plastic. A term used to describe early polyester resin/fiberglass composite material, commonly known as "fiberglass". Technically, I suppose SMC is also a "fiberglass reinforced plastic", but they needed a new name to distinguish it from the old material.
          • Chuck S.
            • April 1, 1992
            • 4668
            #35
            • Terry F.
              • 2061
              #36
              Thanks, Terry *NM*
              • Terry F.
                • 2061
                #37
                Thanks, Terry *NM*
