Weights revisited... Joe/Duke - NCRS Discussion Boards
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Not too many moons ago, either Joe or Duke offered a list of SB/BB engine combo's, with or w/o al heads and ci/al blocks. For us (me) bozo's on the board, would you please repeat that list w/weights? Thanks very much. Dennis
    Re: Weights revisited... Joe/Duke
    Dennis-----
    OK, here it is again:
    all cast iron small block---------------------520 lbs
    al heads with cast iron block small block-----480 lbs
    all aluminum small block----------------------389 lbs
    all cast iron big block-----------------------754 lbs
    al heads with cast iron block big block-------660 lbs
    all aluminum big block------------------------501 lbs
      Dennis-----
      • Dennis C.
        • January 1, 1984
        • 2409
        Thx Joe - Will print/stick on forehead... DC *NM*
        • Dennis C.
          • January 1, 1984
          • 2409
          • Tom Freeman
            Re: Weights revisited... What is included?
            Joe,
            What is included with the engine? Is it a complete long block? or just short block with heads? Or ???
            tom....
            • Tom Freeman
              Joe,
              tom....
                Tom------
                I believe that these numbers reflect the weight of the complete engine, less peripherals such as alternator, starter, pullies, carburetor, etc.
                I'm sure they include intake manifold, but I don't know if they include an aluminum intake with the "aluminum head" engine specs. I expect that they do, though, since you would never really see an aluminum head engine with cast iron intake.
                I do not know if they include exhaust manifolds, or not. However, the main purpose of these weights is to show the RELATIVE difference in weights bewteen the various block/head materials. Whether exhaust manifolds are included, or not, I'm sure that the weights are based on all the combinations either having them installed or not having them installed. So, either way, the RELATIVE weights remain the same.
                  Tom------
