TRYING TO FIGURE OUT WHAT TRANNY THIS IS AND IF IT IS ORIGINAL? ON THE LEFT SIDE OF TRANNY THERE IS A TAG ATTACHED TO THE SIDE COVER # 3952659WB, ABOVE THE COVER CAST INTO TRANNY # 3884685. ON THE RIGHT SIDE CAST ONTO TAILSHAFT # 3857584GM, AND ON THE CASE STAMPED IN VERTICAL # 705407344 AND POCO64 AND CAST ON THE RIHT SIDE # 392566. ALSO LOOKING FOR INFO ABOUT LIFTING THE BODY OFF, DOES SOMEBODY MAKE A HARNESS OR SOME SORT OF LIFTING APPARATUS?
THANKS FOR ANY INPUT
