63 Fuelie - NCRS Discussion Boards
63 Fuelie
  • Tim M.
    • March 1, 2004
    • 24
    63 Fuelie
    I am looking at a 3782870 Block. The engine assebly date off the pad is F0103RF. The casting number is L312. I take this to mean that the block was cast on December 31st, 1962 and then assembled on Jan 3rd, 1963. Is this possible, or would there need to be more time between the casting and assebly.
    Thanks for your help.
    Re: 63 Fuelie
    Nope, that's not atypical.... I've got a '62 327 short block that's also a Christmas-New Year 'baby' with almost the identical date sequence. Remember, it's only about 40-miles from the Saginaw foundry to the Flint engine plant, GM ran their own fleet of transport trucks between the facilities and there were multiple work shifts at the two plants.
    Heck it's even possible for engines to be cast and assembled the SAME day! Consider the case where the block was cast on 1st shift, pulled and transported to Flint on 2nd shift, then assembled into an engine on 3rd shift.... Didn't happen very often, but if inventory was moving hand-to-mouth it could and occassionally did happen.
      Re: 63 Fuelie
      • dean petrucelli
        Re: 63 Fuelie
        Tim,
        I have a 63 FI coupe with a cast date of L72 (November 7, 1962) with a pad date of F1219RF (December 19, 1962) - Just as a comparison
        • dean petrucelli
          Re: 63 Fuelie
          Tim,
          • Michael H.
            • January 29, 2008
            • 7477
            Re: 63 Fuelie
            Tim,
            Is the VIN still on that block? Probably is if the Flint info is still there. Thanks
            • Michael H.
              • January 29, 2008
              • 7477
              Re: 63 Fuelie
              Tim,
              • Tim M.
                • March 1, 2004
                • 24
                Re: 63 Fuelie
                Yes it is vin #3106432. The Engine assebly date is F0103RF. Cast date is L312 and engine code is 378280. The fuel unit is a 7017375--serial number 2898. I can't find anything wrong. How about you?
                • Tim M.
                  • March 1, 2004
                  • 24
                  Re: 63 Fuelie
                  • Michael H.
                    • January 29, 2008
                    • 7477
                    Re: 63 Fuelie Thanks Tim
                    That sounds like an acceptible cast/assy time for the VIN. Thanks Tim
                    • Michael H.
                      • January 29, 2008
                      • 7477
