I recently installed a new turn signal canceling mechanism and spring in my 62. The canceling part works fine EXCEPT-the turn signal lever will not stay in the selected position until canceled by steering wheel rotation, it returns to center as soon as the turn signal lever is released. Has anyone else had this problem? Do I need to modify the selection arms to provide a steeper ramp? I purchased the canceling mech. from Corvette Central if that makes any difference. Also, I can't tighten the friction wedge for the turn signal housing enough to keep it from slipping on the column. Any suggestions here? A shim perhaps? What am I missing?
Bud Landacre
Bud Landacre
