C2 AC Fuel Pump Date Code - NCRS Discussion Boards
  • Eugene B.
    • May 31, 1988
    • 710
    Members,
    Before spending any money to restore my fuel pump, I would like to determine exactly what I have. The pump is stamped 4657LD on the mounting flange. Do I understand correctly that this unit is date coded November 1964?
    Thanks for the help.
    Gene
  • Robert C.
    • December 1, 1993
    • 1153
    Re: C2 AC Fuel Pump Date Code
    I know 65' fuel pumps on base and 300 hp models use that pump.#5594657. The 4657 stamped on the flange. The AC is cast into the top of the upper neck. There is NO date code on the pump that can be seen, therefore not judged.
    • Robert C.
      • December 1, 1993
      • 1153
