Steering Column Assembly - NCRS Discussion Boards
  • Ray C.
    • June 30, 2001
    • 1132
    I am in the process of re-assembling the 1961 steering column after a year of restoration and I should have taken better notes! There is a small U shape copper contact with a single hole. Does this contact attach to a screw that secures the turning signal switch and make contact with the cancellation ring?
    Thanks for any help!
    Ray
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
  • Ray C.
    • June 30, 2001
    • 1132
    Re: Steering Column Assembly
    Correction!
    The clip is not copper and I not sure what it does.
    Ray
    Ray Carney
    • Ray C.
      • June 30, 2001
      • 1132
      Correction!
      Ray
      Ray Carney
      • Ray C.
        • June 30, 2001
        • 1132
        Problem solved!
        Ray
        Ray Carney
        • Ray C.
          • June 30, 2001
          • 1132
          Problem solved!
          Ray
          Ray Carney
          • Dennis A.
            • April 30, 1999
            • 1010
            Ray...
            The parts in the steering housing are the center spring, lock wedge, horn brush and pivot bolt...unless Bubba was around thats about it, including of course the cancel switch ring and turn signal switch/wires.
            • Dennis A.
              • April 30, 1999
              • 1010
              Ray...
              • Ray C.
                • June 30, 2001
                • 1132
                Thanks! Dennis
                The part went to the lower screw of the turning signal switch and I believed it is used for centering. I noticed that there was a different recess at this point, installed it and everything seems to work fine now. I thought I was taking good notes during restoration, but I missed this one.
                Thanks for the response!
                Ray
                Ray Carney
                • Ray C.
                  • June 30, 2001
                  • 1132
                  Thanks! Dennis
                  Ray
                  Ray Carney
