C2 distributor - NCRS Discussion Boards
C2 distributor
  • Steve D.
    • February 1, 2002
    • 990
    Thanks. I think I get it now. *NM*
    • Steve D.
      • February 1, 2002
      • 990
        Re: Help for the helpless
        Swap meets are a great source for used single-point Delco tach-drive distributors; a couple of hours of bench work to rebuild one, get it on a Sun machine to re-curve it to the specs you want, and you're in business.
            #20
            Re: Thanks. I think I get it now.
            Steve-----
            Believe me, you're not going to get a GM #1111069 distributor from Jegs, Summit, GM Parts Direct or any other GM dealer. This particular distributor was GM-discontinued more than 25 years ago. As others have said, you can "create" a distributor with identical advance characteristics from just about any Corvette distributor.
              #21
              Steve-----
              • Donald T.
                • September 30, 2002
                • 1319
                #22
                Ran across this is Hemmings. They have a 111069.
                http://www.hemmings.com/index.cfm/fu...tail/id/546661
                • Donald T.
                  • 1319
                  #23
