Members,
I'll be working on steering linkage for the '65 soon. I'm trying to resolve a discrepancy between the Tripoli Chassis Restoration Guide and the '65 TIM & JG.
Joe states that tie-rod support arms, tie-rod sleeves, and tie-rod clamps are natural and unpainted.
JG says that "The steering linkage assembly including tie rod ends, relay rod, adjusting sleeves and clamps are painted semi-gloss black."
Assuming that the JG is correct, should the ends, sleeves, and clamps be painted as an assembly or separate pieces? It seems strange that the tie rod ends would be totally shot with paint. Over the tapers and rubber boots?
If painted as an assembly, I guess I can see over-spray on the threaded portions. What is the JG trying to tell me?
Gene
Gene
