C3 Speedometer light. - NCRS Discussion Boards
  • MAJohnson
    Hello, I have a 1976 and the light for the speedometer is acting up. When I turn on the lights it will work fine, but when I speed up while driving it will dim out. Only the speedometer light dims out, the rest stay working fine. If I rotate the headlight switch to turn on the interior light the speedometer light comes back on at full power, but will dim after I turn the interior light off. Any info on what the problem might be would be appreciated!
  • Michael W.
    • April 1, 1997
    • 4290
    Re: C3 Speedometer light.
    Try removing and changing the light bulb and inspecting the socket. All the dash lights are in a parallel circuit, so it's likely to be just the one bulb or socket.
    • Michael W.
      • April 1, 1997
      • 4290
