Suggestion C2/C3 Dist. rebuild??
  • Michael Devrous (1787)
    • February 1, 1978
    • 159
    #1
    Hi all
    Does anyone have a suggestion as to who I can have rebuild two dist. /rebuilt right. I had one rebuilt that didn't last 30,000mi. Had the same problem as before. The shaft and bushings were replaced but after 30,000mi. the shaft was loose as a goose. Also, who has the best body removal strap/lift strap. I purchased one but there is no way to adjust the weight balance when lifting the body unless the straps are cut and sewn at different lenghts to lift the body up straight.
    Thanks in advance for your comments Mike D #1787
  • Craig Schultz (29385)
    • July 1, 1997
    • 2471
    Re: Suggestion C2/C3 Dist. rebuild??
    Dave Fiedler at TI Specialty does excellent work......Craig
      • July 1, 1997
      • 2471
      • Terry McManmon (3966)
        • October 1, 1980
        • 15488
        I believe Bill Clupper does this as well. Both Bill and Dave are quite skilled.
          • October 1, 1980
          • 15488
            • February 1, 1978
            • 159
            Thanks Guys *NM*
              • February 1, 1978
              • 159
              Thanks Guys *NM*
