C1 exhaust system removal - NCRS Discussion Boards
  • Chris H.
    • April 30, 1990
    • 817
    I am looking at the exhaust pipes from the mufflers forward. My engine is out now.
    How is this pipe replaced once the engine is in? I assume it can be but since it goes thru the frame twice I wonder?
    Thanks, Chris
  • Mark S.
    • July 31, 1983
    • 655
    Re: C1 exhaust system removal
    The pipes are usually in sections. The header pipe will come through the first part of the frame; and then there will be another section and connection for the mufflers coming from the second cutout in the frame.
    • Mark S.
      • July 31, 1983
      • 655
      • Chris H.
        • April 30, 1990
        • 817
        Are you sure you are talking C1's? Mine is one piece and it looks like the ones available are one piece from the manifolds to the mufflers.
        Chris
        • Chris H.
          • April 30, 1990
          • 817
          Chris
          • Mark S.
            • July 31, 1983
            • 655
            Chris:
            You may want to identify the year; however, I believe the C1's are similar. I have a 56; and I was just working on it last evening. I also have a 65 (C2) fuel car with an off-road one piece system.
            • Mark S.
              • July 31, 1983
              • 655
              Chris:
              • Mark S.
                • July 31, 1983
                • 655
                Postscript: The one piece system that I have for my 65 also has a header pipe connection in the front.
                • Mark S.
                  • July 31, 1983
                  • 655
                    The main run of the original '62 exhaust system was two pieces per side; one from the manifold back through the first "X" member hole, and the muffler assembly included a long inlet pipe that passed through the rear "X" member hole and joined with the front pipe at the hanger between the "X" members with a U-bolt.
                      • Chris H.
                        • April 30, 1990
                        • 817
                        Thanks everyone. Once I knew what to look for I see the LARGE arrow pointing at the pipe where in the blowup view you can see the eged of the pipe.
                        Since I am only doing forward of the dash this year I hope to get the front pipes off and replace them.
                        Chris
                        • Chris H.
                          • April 30, 1990
                          • 817
                          Chris
                          • Dave Suesz
                            An excellent photo in Adams' book...
                            ...in the 56 section, shows a fully installed exhaust system in a chassis with an engine/trans assembly held above. I suggest you do it GM's way, since the engine is out now.
                            • Dave Suesz
