I recently removed my exhaust manifolds, heat riser, and dual side pipes for a thorough cleaning and touch up on my '66 327/350hp. When I went to replace the heat riser gasket I noticed that the prior/pre-existing gasket had a 2.5" dia opening vs. my replacement which had a 2.0" opening. Both parts fit nicely over & around the locking bolts/nuts. When viewed from above, in a direction that the exhaust gases flow, the top opening of the heat riser is roughly the same as the new gasket. I thought that all 327cid for my year had exhaust outlets that were of 2.0" diameter and that was what I asked for replacement size. Why would there have been a larger gasket? I doesn't seem that the smaller 2.0" gasket restricts air flow. Which should be the correct size?
As an aside, what exactly does the heat riser do? It appears similar in function to a choke, yet I have heard of some owners removing the 'butterfly plate' inside for completely unrestricted air flow.
