I have a 1966 327 300 original drivetrain, but highly customized award winning "show" car. I do not drive it much at all, however when having an oil pan gasket repaired, the mechanic noticed small drops of radiator fluid coming from one of the cylinders that had been re-sleeved when the engine was rebuilt. He said that given how little I drive it, this may not be an issue, but that radiator fluid will eventually break down the oil and ruin the engine if left untreated. He gave me 3 options. . . rebuild the engine again to try and fix the leak (cost and result unknown since he would not do this); remove the original engine and put a crate motor in ($5,000+) or try running a fluid with a ceramic engine sealer product through the engine that has supposedly been used in Nascar to seal small during races. For now we are going to try to find this sealer and give that a try.
Does anyone have any experience in a similar situation and recommendations?
Is anyone familiar with this ceramic sealer product and whether it really works long term?
Thank you very much.
