Gen IV Small Block 3 Valve (2006 Z-06)
Re: Gen IV Small Block 3 Valve (2006 Z-06)
Geezer-----
I'm not completely sure, myself. However, they seem to be activated by a secondary pushrod that is somehow activated by the intake valve rocker shaft. I can't discern just how this is accomplished, though. It may be off a cam on the intake rocker shaft or some other mechanical arrangement.In Appreciation of John Hinckley- Top
Addendum
Geezer------
I think that I've got it figured out now. The rocker arms are shaft mounted. The intake pushrod activates the intake rocker arm which then actuates both intake valves, apparently simultaneously (or, perhaps, slightly "phased" by the actual configuration of the rocker arms to each valve). A PRIMARY exhaust pushrod activates the shaft-mounted exhaust rocker arm. This rocker arm then actuates the pedestal-mounted, exhaust valve rocker arm via the short SECONDARY pushrod.In Appreciation of John Hinckley- Top
