C1 Sticky Clutch - NCRS Discussion Boards
C1 Sticky Clutch
  • Dennis A.
    • April 30, 1999
    • 1010
    C1 Sticky Clutch
    I would appreciate any suggestions for fixing a sticky (no return) 1961 clutch pedal. The clutch pedal goes to the floor and stays there, I'm not sure how to adjust the over-center return spring, the clutch fork push rod seems to be set correctly. Any ideas were to start?
  • Terry D.
    • May 31, 1987
    • 2690
    Re: C1 Sticky Clutch
    Try taking the over the center spring out. Worked on my 62. Check the archives, been several posts about that spring.
