85 TPI - stalling - NCRS Discussion Boards
85 TPI - stalling
  • Loren L.
    • April 30, 1976
    • 4104
    85 TPI - stalling
    Just had the EGR replaced on the '85 with 130K - car will now stall, without warning, no discernible pattern - but will immediately restart. It's been suggested lack of proper fuel pressure, but that doesn't seem to fit with the immediate restarts. Ideas???
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: 85 TPI - stalling
    sounds like the new EGR valve maybe sticking open when the engine returns to idle which will cause a stalling condition
    • Loren L.
      • April 30, 1976
      • 4104
      Clem - is there a way to check for this
      short of taking it apart??
      • Clem Z.
        • January 1, 2006
        • 9427
        Re: Clem - is there a way to check for this
        the only way i can think of is disconnect the EGR so it does not open and see if the problem goes away. this will work if it is a vacuum operated EGR valve but if it is a electric operated i have no clue how to check the operation as they came out after my stint as a mechanic. some were also back pressure operated. you could remove it and make a block of plate for the engine and try that.best that i can come up with
        • Jim T.
          • March 1, 1993
          • 5351
          The 85 has a vacuum operated valve.
          • Clem Z.
            • January 1, 2006
            • 9427
            then all you need to do is pull the vacuum hose and plug the hose to keep the EGR valve from operating.
