Carbon clogged C3 Intake Manifold - NCRS Discussion Boards
  • Greg Metzler
    OK... my '68s carb and ignition system are running the way they were designed...
    However, the intake manifold is completely gunked up with carbon. Any suggestions on how to remove it?
    Re: Carbon clogged C3 Intake Manifold
    Greg-----
    If you're talking about the carb heat groove in the front of the carb flange being "gunked up with carbon", that's a GOOD thing. However, in that case I recommend that you drill the carbon out of the 2 holes on either end of the groove and install soft (cup) plugs or pipe plugs to eliminate this carb-destroyer for good.
    If you're talking about carbonized oil on the bottom of the intake, you need to remove the manifold oil shield by prying out the 4 drive rivets that retain it to the manifold. Then, you can chip away all of the carbon with a hammer and chisel (carefully, of course). If you wish to get it completely clean, you can then take it down to the local machine shop for a hot tank (best, if they still have it) or high temperature oven cleaning.
    To replace the shield, either use new drive rivets (GM #10229247) or drill and tap the holes for machine screws, installed with Lock-Tite. I do the latter.
