66 power antenna - NCRS Discussion Boards
66 power antenna
  • Rob M.
    • April 30, 2003
    • 657
    66 power antenna
    Hi,
    Could someone recommend a good rebuilder for a 66 power antenna motor.
    Thanks in advance
    Rob
    '66 327/300 Regional Top Flt
    '08 6 speed coupe
  • Joe C.
    • August 31, 1999
    • 4598
    Re: 66 power antenna
    OEM Glass, at (309) 662-2122. It is not cheap.
    • Steve Pettit
      Is there a good, functional replacement for a driver? I would like to put off the repair of my original until the day comes (that day starts the day after I retire) when the restoration kicks into gear. I would be interested in something that required no permenant alterations, and that worked well. And is cheap and easy, and... but I suppose that is getting carried away.
      Thanks as always,
      Steve
      • Richard Hayes
        Steve,
        I just replaced mine w/ a reproduction. There are several guys out there that sell this "Taiwan" or "China" made piece. Around $170- plugs right in to the harness-and really easy to install-IF you have sidepipes. Otherwise you'll probably have to drop the muffler.
        Richard
        • Rob M.
          • April 30, 2003
          • 657
          Joe,
          Thanks for the suggestion. I appreciate it.
          Rob
          Rob
          '08 6 speed coupe
          • Dick W.
            • 10483
            OEM Glass @ (800) 283-2122
            Dick Whittington
